Hello!
Today I wanted to upgrade my ESXi 5.1 to 5.1Update1.
I used the command
to download and start the update procedure, but after some time, I get the summary which says nothing was install, nothing was removed and all VIBs were skipped:
My current profile is an updated 5.1:
As far as I was looking at VIBs version numbers, there are definetly newer packages in the new update, but it just doesn't want to update.
What am I doing wrong?
Matj
I used the command
Code:
esxcli software profile update -d https://hostupdate.vmware.com/software/VUM/PRODUCTION/main/vmw-depot-index.xml -p ESXi-5.1.0-20130402001-standard
Code:
Update Result
Message: Dryrun only, host not changed. The following installers will be applied: []
Reboot Required: false
VIBs Installed:
VIBs Removed:
VIBs Skipped: VMware_bootbank_ata-pata-amd_0.3.10-3vmw.510.0.0.799733, VMware_bootbank....
(Updated) ESXi-5.1.0-799733-standard
Name: (Updated) ESXi-5.1.0-799733-standard
Vendor: hyper
Creation Time: 2013-02-13T00:38:43
Modification Time: 2013-05-22T06:43:43
Stateless Ready: True
Description:
2013-02-13T00:38:43.350798+00:00: The following VIBs are
installed:
esx-base 5.1.0-0.9.914609
tools-light 5.1.0-0.9.914609
The general availability release of VMware ESXi Server 5.1.0
brings whole new levels of virtualization performance to
datacenters and enterprises.
Matj
