Upgrading the AS Rock WiFi Antennas??? Need help
bizzmeister
Hey guys,
Was just curious. Can I upgrade the dual smaller antennas that came with my motherboard for bigger/ more powerful ones?
Also, which brand would be best? What do you guys recommend?
Just trying to squeeze out as much performance as I can wirelessly. I’m on a 400mb a sec connection on my wired build but with this build I’m working on here, I get around 250 down.
On steam, my hard wired PC downloads at 65 megs a sec which is blazin fast. I get around 24mb/sec downloads on my 5.0ghz WiFi build.
Dead Parrot
If your MB has standard connectors for the antennas, you might be able to use something like this: https://www.amazon.com/Universal-Directional-Connector-connectors-Extenders/dp/B0765ZKWV9/ref=sr_1_14?keywords=wifi+antennas&qid=1580053251&sr=8-14
If your existing antenna(s) are mostly hidden behind a metal case, much of the benefit may come from getting them clear of the metal. You lose a bit in the cable but might gain more with the larger and fully exposed antenna.
Don't have a specific brand recommendation. Reused an old antenna from a dead AP on my then new(but now well past EOL) AP.
