Looking to upgrade my Dell 27" 1920x1200 monitor that I use as a PC monitor for general home use (i.e. occational light gaming, browsing, movies, emails/documents etc.). Right now I'm considering IPS 2560x1440 monitors and looking at either the Dell U2711, the Hazro HZ27WD (with glass screen and lots of connectors) for about the same price, or the Hazro H27WC without the glass screen and only dual link DVI connectors for significantly less. Have done a bit of research and here's what I have so far:
Anyway, currently favouring the Hazro H27WC over the others. Any views, suggestions or recommendations here?
- The two Hazro's have the same glossy screen as the Apple Cinema Display 27" while the Dell sticks to it's usual aggressive anti-glare coating for office use. Even though I use Dell's all the time, this is for home use and I'm and favouring the clear screens of the Hazro's (or Apple Cinema Display) for a change.
- Not sure what advantage, if any, having a glass screen has when placed over a glossy screen. Guessing if it has any effect, it makes it even more reflective and this is actually a bit of a negative, so favouring the Hazro H27WC over the WD. In theory. Anyone have some experience on this?
- The Hazro HZ27WD and Dell U2711 have a lot of connectors while the WC only has dual link DVI. But for a general purpose PC monitor, how does this actually help at all; why plug in a low resolution HDMI cable into a high res monitor; only advantage I see is that they handle display port which is a thin, nice looking cable, if you're into that...
- I can purchase the Hazro H27WC for around 35% less than either the Hazro HZ27WD or the Dell U2711. If I pay double I can get a 30" Dell monitor or a 27" Apple Cinema Display. Big price increase, but a good display is a bit of a long term purchase not something you change each year. Anyone think I should consider saving up for the 30"? If so, any good 30" monitors around (ideally without full anti-glare for office work).
- The Hazro's comes with a 3 year retailers warranty while the Dell comes with 3 months.
- Reputation wise (and probably resell value wise), it's no contest. The Dell is a Dell, #1 office computer supplier, while who knows what a "Hazro" is.
- The Dell U2711's stand is superior to either of the Hazro's.
- A big unknown is the electronic sound. Bascially the hissing you hear from monitor when everything is quiet. No idea on either the Dell or the Hazro and reviews never tell me anything. Anyone have a Hazro or Dell and can report on this?
