Upgrading from Win xp pro to Windows 7?
GMcDougal
i thought i read that its not possible to upgrade from win xp to windows 7. ive been holding out from buying windows vista 64 so i can get windows 7. am i going to be forced to buy windows vista?
Sovereign
You can certainly upgrade (XP owners are eligible for upgrade pricing) but what you cannot do is a in-place upgrade that leaves all your settings and files alone. You must do a clean install. Unless you want to borrow someone's Vista disk, install it as an upgrade trial, then install 7 on top of that, activating Windows 7 and using Vista as a bridge. I don't know if 7 will allow that (upgrading from a Vista trial).
Arainach
You're eligible for upgrade PRICING (i.e. you can buy the upgrade installation), but you can't actually upgrade unless you upgrade XP to Vista and then upgrade Vista to 7; you'll have to wipe the HD and do a clean install.
Bcc335
I'm also holding out for windows7, glad to know I can at least get upgrade pricing. :) I'll be doing a clean install when it drops. Didnt know about the vista upgrade trial to win7 route. Interesting
Just wondered how many of you downloaded Windows 7 RC this morning? Well, I did and, while I ran into several, not unexpected problems, it looks very promising. No compatible drivers from Logitech and only beta drivers for my X-Fi card from Creative. Boot up is relatively quick, can't say the same for shut down. So, what's your experience been so far? I'm not a gamer so I can't comment in that area.
