Because after installing my gtx 570 card nothihng shows up on my screen. It's not recognizing the hdmi.
I'm trying to upgrade from hd 6850 to gtx 570. Can someone give me the proper steps in doing so?
thats not hardly an upgrade...
you have the 570 powered with 2 6pin connectors?
Can you tell if your computer is booting anyway? Like, do you see the hard drive LED blinking away? If you have onboard video, you could try booting with that to see if the GTX570 is being detected at all. Tell us more about the rest of your system, particularly what motherboard and power supply you are using.
I think the upgrade makes great sense actually. The 6850 is one of AMD's last cards before they switched from the VLIW5 architecture over to GCN. Because of this, the 6850 is stuck using legacy drivers. The newest legacy drivers date back to July of 2015, with a beta available from Feb of 2016. Obviously, things are going to be iffy with new games and it's only going to get worse as time goes on. The GTX 570 on the other hand, is still supported by the very newest Nvidia drivers, the same drivers that you would download if you had a GTX 1080.
Intel Core2Quad q8300
6 gb ram
ocz 750 psu
currently: hd 6850
out of these parts, is the cpu the one I actually need to upgrade to improve FPS?
6 gb ram
ocz 750 psu
currently: hd 6850
