I'm planning to buy 8700k to upgrade my [email protected] (with Asus GTX1070) once I get lucky and I find one in stock. I'm planning on delid it using rockitcool88 toolkit.
What is the best/decent mobo I can buy for it in order to o/c to 5ghz (or at least try it).
I'm thinking of buying following:
ASRock - Z370 Extreme4 ATX LGA1151 Motherboard
Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory CL15 ~OR~ 3200 CL16 (whatever is cheaper)
Noctua - NH-D15 82.5 CFM CPU Cooler
EVGA - SuperNOVA G2 750W 80+ Gold ~OR~ Seasonic FOCUS Plus Series SSR-750FX 750W 80+ Gold
Any comments? Or suggestions?
I'm reading there are some issues with Asus/Asrock mobos supplying voltage? I like MSI, is there good MSI mobo I should consider?
I don't care about AC/wifi features, but more about stability and good power phase support for overclocking.
Any help would be much appreciated.
Thanks in advance..
Thanks in advance..
