gordy_hand said:You have two sticks of 256mb in the powerbook if its the stock one. 256mb is soldered onboard and 256mb is in a stick seperatly.
If you get a 1gb stick you are supposed to be able to see the difference, I've just ordered a gb stick for mine , it should be here the day after tommorow I will let you know what its like if you wish.
CSx-2011 said:The iBooks and 12" Powerbook share that ram configuration. The 15" and 17" PB's have two slots.
From tech specs for 15/17 PB
"512MB PC2700 (333MHz) DDR SDRAM, single SO-DIMM"
T-Bird 151 said:Gordy, let me know how the memory upgrade goes...I'm really tempted to plop down some bucks to get up to 1 GIG.
