Well, where I work, automation is king. If it can be automated, it should be. And no, people aren't being let go because of it... if you know your stuff, you're kept around as there's always new things to automate and make better. I'm also not sure what your job is or what your goals really are, so there's not a lot of opportunity to "help" you.
With that said, what you have is pretty alright. Maybe bump the RAM a little. Build an ESX host from it (or spin up ESX/vCenter VMs), and spin up a few ESXi VMs and maybe a couple of very tiny linux VMs. Poke the UI for a couple of hours, then start digging into PowerCLI. If you're just a person who tinkers with virtualization though, or only does some simple stuff for your job (i.e. spin up a few VMs, change resources, install/config ESX by hand), that can all be learned by anyone in an hour or so. If that's the case, you might just be better signing up for the Hands on Labs from vmware.
My only concern is if you need to do passthru such as a M1015 for FreeNAS you're stuck because the 4670K doesn't support VT-d.
If you aren't doing passthru then the only thiing you really need is more RAM, ideally 32GB.
for any lab, its best to keep it separate from prod or in this case, your gaming machine. The assumption is that you have things up and running with your current machine, and erasing everything to self study could negatively impact you (esp on days you need to chill out and not study).
Currently work for a large automotive corporation, as senior deskside/ executive support. I support 2,700+ clients in my building and 33 executive level employees over 5 buildings. In my spare time i self study for new exams to get certified in to help open up my career prospects. Right now I'm studying for the security+ exam, then the vmware vcp6-dcv I have setup up an esxi host previously but that was by reading some forums and YouTube. This rig will be used for self study.
