Updated: Added a new post with lots more in depth details about my search!
Hey guys I think this is probably to ask so I'm hoping some of you have some good ideas for me.
Currently running a new 7700k build in an old Fractal Design Define R3 that I'm ready to retire.
I had been hoping we'd see the release of a new R6 model, but it seems with the Define S and Define C the R5 might be around for a bit. As I've been hanging around in limbo on this the idea of moving to mATX came to mind. I'd only need to swap out my motherboard for an mATX model and I'd be good to go.
The real killer here is what case to go with. I'm heavily considering the highly acclaimed Eisbaer 240 to make the move to water at the same time. Add in that I do require 1 5.25" ODD drive bay for my BD-R and the field narrows considerably. I've looked at many many cases and most seem to be either "No ODD for you!" or "Hey lets have 2 or 3 ODD bays in a small case!" greatly diminishing their ability to handle a 240mm AIO.
Hoping you guys have some good ideas I've not seen yet.
Thanks!
Edit: Specific Hardware Requirements
Component Details:
GPU - 1x MSI GTX 970 LE is 277mm
PSU - Seasonic Prime Titanium 750W is 170mm
Alphacool Eisbaer 240mm is 55mm thick with fans. I don't believe this qualifies as "slim" and many cases claim support for a "slim 240mm". Please correct me if I'm wrong.
ODD - Full size BDR
HDD - 2x WD Blacks 3.5"
SSD is M.2 so no 2.5" drive capacity is required
Thanks!
Component Details:
ODD - Full size BDR
