I recently purchased dual BFG 7800GTX's for my system. However, the core clock speed is at 275mhz, which seems very low according to what the stock clock should be. This is from Riva Tuner.
$1100000000 Title : GeForce 7800 GTX VGA BIOS
$1100000002 Version : 5.70.02.11.25
$1100000100 BIT version : 1.00
$1100000200 Core clock : 275MHz
$1100000201 Memory clock : 1200MHz
$1100010000 Perf. level 0 : 275MHz/650MHz/1.20V/100%
$1100010001 Perf. level 1 : 415MHz/650MHz/1.40V/100%
$1100010002 Perf. level 2 : 460MHz/650MHz/1.40V/100%
$1100020000 VID bitmask : 00000011b
$1100020100 Voltage level 0 : 1.20V, VID 00000000b
$1100020101 Voltage level 1 : 1.30V, VID 00000010b
$1100020102 Voltage level 2 : 1.40V, VID 00000001b
It appears that the 460mhz clock speed is in there, but do I need to change a jumper setting or voltage in BIOS to get the 460mhz clock? I'm using the 77.72 drivers, on a Foxconn NFPIK8AA nforce4 Pro mobo.
