Having used Smoothwall and pfSense for the past 2 years and after reading the recommendations by YeOldeStoneCat and others, I figured I would try it out. I found an old Dell motherboard at work and set out using that.Here's the specs.
Dell motherboard (can't remember the model, at work at the moment, can't check...)
Onboard Broadcom Gigabit
1 GB DDR RAM
80 GB 2.5 SATA HDD
P4 3.2
Second Dlink DFE-538TX PCI card.
Anyways, I got it installed and everything with no problems. I installed the apps into the rack. Everything is working how it should, I tested the virus scanning and protocol blocking and everything, it's working real nicely, I like it alot. My only problem is port forwarding. I have been trying for a couples hours the past 2 nights trying to get port forwarding. I've been searching Google, trying all these tips on forums and following their configs, but I'm getting nothing. If I use the default rule that's in there of port 80, it forward just fine. I've been using the online utorrent port checker. It says port 80 is open. I disable the rule, it says the port is closed. Alright. I change the port from 80 to any other port number, it doesn't forward! This is driving me insane. I've tried pretty much everything that I can. I really don't want to go back to Smoothwall or pfSense. Any suggestions guys? Thanks.
1 GB DDR RAM
80 GB 2.5 SATA HDD
P4 3.2
