If I buy a unsubsidized iPhone 5 from Apple, then bring it in to a Verizon store and tell them to activate this phone, I should not lose my Unlimited LTE as i wont be touching my contract. Is this correct? Want to replace my galaxy Nexus.
Assuming they will both use a micro-SIM
they switched to nano-SIM
Actually, the nano-SIM will be the new standard, BUT... Of course Apple developed their OWN nano-sim standard, which is incompatible with what everyone else has been trying to standardize. It's never easy once Apple gets involved.
Of course they did. They can't use the same standard as everyone else! As if the micro-SIM wasn't small enough .
Don't forget to allot another $30-$40 for your port adapter so you can use all your old cables/accessories, OP!
Thats fine with me, I dont have accessories.
What if I were to do the same thing as the OP, but I currently don't have 4G (using a 4s now). Would my unlimited data plan remain untouched?
You are correct.from everything I have read that is correct
but I can't for the life of me understand why you would want to make that switch
