I have a unknown device listed in the Device Manager, when I checked it with an application it came back as a usb device from Microsoft...
This is someones computer I'm working on, they had spyware and viruses on it, and they were messing with the registry.
None of the USB areas in the Device Manager show anything in question, only this unknown device which is listed under the System Devices.
http://img168.imageshack.us/my.php?image=91857605cc8.jpg
Not really to sure how to go about finding what driver this is, I've already installed the chipset drivers and reflashed the bios.
This is a Dell XPS 410:
http://support.dell.com/support/dow..._PNT_9200_XPS_410&os=WW1&osl=en&catid=&impid=
Besides the chipset and Bios not sure what else this could be unless it's related to SATA...
For me the box runs great, and personally I'd love to disable it, and not keep getting the wizard popup when you restart, but it has a checkbox to not prompt you anymore for the software for the device, but when I check it, it just prompts you again, LOL, stupid thing won't stop prompting you to install drivers. Is there a way anyone knows how I can disable the driver prompt?
THANKS
THANKS
