Vengance_01
- Dec 23, 2001
I am getting my USG setup and new unifi POE switch. Both my APs are seen as uplinks and I created the separate Guest Wifi network, IP range, DNS setting and set the VLAN. Wifi SSID is tagged with same VLAN. My uplinks are tagged for this VLAN (aka set as a trunk port) and my guest clients get the correct IP and DNS settings but I am not getting at hits in openDNS and Filter is not working. Thus some how I think the USG is redirecting traffic to a different DNS server. I don't want to filter all clients just guest Wifi for for porn, guns, malware, etc... since I do leave it open(with limited speed) so I don't need to tell ppl the password.
Extra config info.
Current default internal is on 192.168.1.1/24 LAN1 Static DNS is set to Pie Hole(internal address)
USG: 192.168.1.1
Guest Wifi VLAN 172.0.0.1/27 DNS OpenDNS
WLAN no VLAN, DHCP IPV4, DNS set static 1.1.1.1 and Quad 8's
Default out of box FW rules
What the fuck am I missing.....
Extra config info.
USG: 192.168.1.1
