Unfinished 6ft Butcher Block countertop/desk top slab $120 (Home Depot, YMMV)
bonehead123
Nice deal, I bought several of these years ago when they were alot less, but still a good deal. And at 1.5" thick, they make solid desks/tables etc. for just about any use...
I trimmed mine with solid oak moulding and finished them off with that super-duper-tuff clear stuff that is used on basketball courts, and they still look as good now as they did on day 1 :)
Mad[H]atter
Blood Diamond Dealer
I wonder if it's zipcode based, showing $169 here.
Edit* It is, I updated zipcode to WA and it shows the 120.
vegeta535
Was showing $120 for me when he first posted but yea back to $169. I rather it be 30" deep tho.
sfsuphysics
May be cheaper near where the lumber is cut. On one trip from Canada to California I remember driving down the highway with the windows open on a nice day and just for a couple miles I had the scent of fresh cut lumber wafting through the car. Some people get a high from the smell at pumping gas, I get it from wood.
That said, if you have some simple tools you can totally make your own butcher block, with some effort. If you're not super duper picky about it being ultra square, you can even do it without a jointer or planner, just a power sander, facemask and patience :D
I used these: https://www.ikea.com/us/en/p/gerton-tabletop-beech-50106773/
61 x 29 1/2 x 1 1/2 thick @ $100 each​
I put two together in an L shape with some white square legs from Ikea at each corner. I also used a cross brace at most corners since it wobbled without them.
I didn't finish it with anything other than this: https://www.amazon.com/gp/product/B001BKQYGW
Do you have a picture of the finished product? That sounds about like what I need to do for my space.
Burticus
J Macker
Dang that would be great! I would prefer 29.5" depth.
I wish Ikea would ship them to my zip code. It simply states unavailable. They don't have stock of them in Renton, WA nor Portland, OR.
Bellz
Another suggestion could be a butcher block from Home Depot, although they're fairly expensive and you'll still have to buy legs.
https://www.homedepot.com/b/Kitchen-Countertops-Butcher-Block-Countertops/N-5yc1vZcgrc
Or you can do what I did and find a used kitchen table on craigslist or fb marketplace for cheap. I paid less than $100 for a 5'x3' table.
I have a dual-monitor arm holding two 32" monitors and have plenty of room. I'd post a pic of it, but my work area is a mess right now. :)
Erebus
This was a 100% IKEA build using something similar to what the OP and others have posted. I used dowels glued to the stands to keep the desktop in place but still allow easy disassembly / movement. Stain and poly dressed it up a bit. The stands are height / tilt adjustable however I typically just leave it at the lowest setting. The stands were also assembled with wood glue in addition to the typical IKEA fasteners, they are pretty solid.
croc_
That looks so nice!! Now I want to stain and poly mine, but I might have screwed myself by putting the wax/oil on it.
I built a sit/stand desk from this:
Ikea $59 - 74" x 25 5/8" x 1 1/2" - I needed length more than depth.
https://www.ikea.com/us/en/p/saeljan-countertop-oak-effect-laminate-80439214/
I can take a photo for anyone that wants to know how it looks.
I was tempted to use this too since it looks really nice. I was worried that since it's a laminated particle board it wouldn't hold my 3 Ergotron monitor arms very well. Do you use clamped monitor arms on yours?
