Unable to Start Thermalake 750W SP-750P start up by short PS_ON pin to COM. Nothing happened.
jgy2001
We have a never been used Thermaltake 750W SP-750P ATX power supply. We tried to start this power supply.
On the 24 pin connected, we shorted the pin #16 (PS_ON) to pin #15 (com) with jumper.
We connect the power to 110VAC. Turn the switch on.
Nothing happened.
Did we do something wrong there?
Tried to contact Thermaltake customer service for weeks, no response. What happened?
Thank you for your help.
jgy2001
To Be purchase:
Intel i0-9900K 3.6G 8-core
Noctus NH-D14 64.95 CFM Cooler
Asus Prime Z390-A ATX LGS1151 motherboard
Corsair Vengeance LPX 32 GB (2x16GB) DDR4-3200 memory
Seagate Barracude 1 TB 3.5" 7200rpm Internal hard drive
SanDisk Extreme Pro 480GB 2.5 Solid State Drive
Asus GeForce GTX 1050 Ti 4GB Phoenix Video Card
Already have:
Corsair 750D ATX Full Tower Case (undecided)
Thermaltake Smart Pro 750W SP-750P ATX Power Supply with 6 inch (160mm) fan - dead, unable to start
LG WH14NS40 Blu-Ray DVD Writer (already Have)
Win 7 Professional 64 Bit (Already Have)
Dell U3011 30" 2560x1600 60Hz Monitor (Already have)
GiGaBiTe
Make sure you're shorting the correct pins, it looks like the entire wire set is black going to the ATX connector, which can make it difficult to be sure you have the right pins shorted.
You might want to just try plugging it into a motherboard and see if it powers up, because a DOA PSU is pretty rare.
jgy2001
Thermaltake claimed since we do not have original invoice or purchase receipt, they will not honor any warranty. Now these Thermaltake power supplies are junk.
Think twice buying this brand. Highly NOT recommend this brand.
GiGaBiTe
Quite a few companies won't honor warranties without a receipt/invoice, you can't knock TT for that. Warranty fraud is a big problem.
Maybe you can find someone that can diagnose your power supplies to give you a second opinion.
Smoblikat
Its possible the unit is DOA, but my experience with thermaltake warranties/PSUs has been pretty great. Have you tried plugging it into a machine and using it as normal? Is the power strip the PSU is connected to turned on? :p (been there)
