Hi All!
Wanted to see if anyone else has run into this issue before.
Using Ubuntu 16.4, I installed version nvidia-387 and Cuda 9.1
my start.bash has
when I issue nvidia-smi you can see the GPU 2 not honoring the settings
but everyone else in the system is honoring the commands.
does anyone have a suggestion on how to fix?
my start.bash has
Code:
sudo nvidia-settings -c :0 -a [gpu:2]/GPUMemoryTransferRateOffset[3]=525
sudo nvidia-settings -c :0 -a [gpu:2]/GPUGraphicsClockOffset[3]=150
sudo nvidia-settings -c :0 -a [gpu:2]/GPUFanControlState=1
sudo nvidia-settings -c :0 -a [fan:2]/GPUTargetFanSpeed=95
Code:
Sun Dec 17 11:41:39 2017
| NVIDIA-SMI 387.26 Driver Version: 387.26 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce GTX 106... On | 00000000:01:00.0 Off | N/A |
| 95% 52C P2 71W / 73W | 2429MiB / 3013MiB | 100% Default |
| 1 GeForce GTX 106... On | 00000000:02:00.0 Off | N/A |
| 95% 46C P2 72W / 73W | 2429MiB / 3013MiB | 98% Default |
| 2 GeForce GTX 106... On | 00000000:03:00.0 Off | N/A |
| 62% 53C P2 72W / 73W | 2423MiB / 3013MiB | 99% Default |
| 3 GeForce GTX 106... On | 00000000:05:00.0 Off | N/A |
| 95% 52C P2 72W / 73W | 2429MiB / 3013MiB | 100% Default |
| 4 GeForce GTX 106... On | 00000000:08:00.0 Off | N/A |
| 95% 55C P2 73W / 73W | 2429MiB / 3013MiB | 100% Default |
| 5 GeForce GTX 106... On | 00000000:0A:00.0 Off | N/A |
| 95% 50C P2 72W / 73W | 2429MiB / 3013MiB | 100% Default |
| 6 GeForce GTX 106... On | 00000000:0C:00.0 Off | N/A |
| 95% 50C P2 73W / 73W | 2429MiB / 3013MiB | 100% Default |
| 7 GeForce GTX 106... On | 00000000:0D:00.0 Off | N/A |
| 95% 51C P2 74W / 73W | 2429MiB / 3013MiB | 99% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 824 G /usr/lib/xorg/Xorg 5MiB |
| 0 1320 C ./ethdcrminer64 2403MiB |
| 1 824 G /usr/lib/xorg/Xorg 5MiB |
| 1 1320 C ./ethdcrminer64 2403MiB |
| 2 1320 C ./ethdcrminer64 2403MiB |
| 3 824 G /usr/lib/xorg/Xorg 5MiB |
| 3 1320 C ./ethdcrminer64 2403MiB |
| 4 824 G /usr/lib/xorg/Xorg 5MiB |
| 4 1320 C ./ethdcrminer64 2403MiB |
| 5 824 G /usr/lib/xorg/Xorg 5MiB |
| 5 1320 C ./ethdcrminer64 2403MiB |
| 6 824 G /usr/lib/xorg/Xorg 5MiB |
| 6 1320 C ./ethdcrminer64 2403MiB |
| 7 824 G /usr/lib/xorg/Xorg 5MiB |
| 7 1320 C ./ethdcrminer64 2403MiB |
