Unable to Play HD DVD or Blu Ray
Discussion in 'Home Theater PCs & Equipment' started by mir, Sep 22, 2008.
  1. mir
    mir Limp Gawd
    199
    Apr 4, 2007
    Hi there I can't play Blu Ray Disc or HD Disc.
    My Computer does not even show Disc in there.
    However DVD and CD works fine.
    HD DVD I have tried was Ocean 13 and Blu Ray Disc was XXX
    My Computer is as follow
    Video Card: GeForce 8800 GTS
    Optical Drive GGC-H20L (LG)
    CPU is E3110
    Mem = 3.5 Gig
    OS XP SP3 32 Bit
    Monitor is Samsung Sync Master 245 bw Hooked via DVi
    Player is from LG Cyber Link 7.3
  2. StorageJoe
    StorageJoe Limp Gawd
    460
    Jun 14, 2005
    Did you download the updates to PowerDVD to support HD-DVD and Blu? I had to download updates before I could get any HD discs to play.
  3. Adidas4275
    Adidas4275 [H]ardness Supreme
    5,956
    Mar 11, 2006
    yeah you need software, you cannot use a HD/bluray dive w.o software with out powerDVD or something similar
  4. BIGJ
    BIGJ Gawd
    858
    Dec 19, 2006
  5. mir
    mir Limp Gawd
    199
    Apr 4, 2007
    I will look into it
    I can't seems to be able to D/L the Updates
