Unable to get Yahama RX-V567 to do 1080p output via HDMI
Discussion in 'Home Theater PCs & Equipment' started by masterosok, Jun 19, 2017.
  1. masterosok
    masterosok Gawd
    934
    Apr 1, 2008
    I have my PC feed to the HDMI 1 input on my receiver then the HDMI output from the receiver to the TV however the best I can get it to do is 1080i. I have the input settings set to 1080p and when I connected the PC direct to the TV 1080p works fine but for some reason the receiver won't out put to 1080p. I have tried other HDMI inputs on the TV and receiver.
    I have no clue what could be causing the issue. Anyone have any suggestions that might help?
  2. bloodypulp
    bloodypulp Gawd
    898
    May 17, 2010
    try turning HDMI Setup, Control to OFF [CEC]
  3. masterosok
    masterosok Gawd
    934
    Apr 1, 2008
    Will give that a try. Thanks!
