Ultrafire CREE XM-L T6 Zoomable-2000 Lumen Tactical LED Flashlight $4.75 Free Shipping eBay
Discussion in '[H]ot Deals Discussions' started by Kyle_Bennett, Apr 18, 2016.
  1. Maddnotez
    Maddnotez Limp Gawd
    197
    Nov 28, 2014
    Actually I may have spoke to soon. The second one was broken. It lights up fully zoomed out but the zoom settings don't work, can't zoom in at all. Not even sure if it's worth the hassle of returning it.
  2. TechLarry
    TechLarry Pick your own.....you deserve it.
    28,017
    Aug 9, 2005
    He may just tellyou to trash it and send you another. You never know.
    I get the feeling he has like 50c a piece in these.
  3. chimera996
    chimera996 [H]ard|Gawd
    1,062
    Sep 4, 2010
    The zoom is controlled by a metal ball and spring. I bought 5, only tested 3 so far. I also bought batteries per link by noxtek and was surprised by how large they were. At first I said fuck this isnt going to work and thought about emailing the seller. Then I took the AAA battery holder out and popped one of the large single batteries in and bam! It worked, charging 4 batteries I bought with the two chargers as I post this.
  4. Montu
    Montu [H]ard DCOTM x4
    7,005
    Apr 25, 2001
    Got both of mine and they work great. For the price I'm very pleased.
  5. AMD_Gamer
    AMD_Gamer Pick your own.....you deserve it.
    18,427
    Jan 20, 2002
    You guys still like this flashlight after having it for a while?
  6. LOCO LAPTOP
    LOCO LAPTOP [H]ardForum Junkie
    9,845
    May 4, 2006
    +1 and any updates on runtime?
  7. TypeO
    TypeO [H]ardness Supreme
    6,842
    Nov 1, 2000
    Bought 4...2 are broke. The issue is that the zoom ring or whatever you call it no longer turns and whatever position it was in at the time it failed, that's the light output you get. The first one broke the day I received it. The second one broke a week later. Honestly haven't used the other two at all. Still have no idea how to fix the ring or if it can be fixed. It's just locked up.
  8. Maddnotez
    Maddnotez Limp Gawd
    197
    Nov 28, 2014
    Same here.
    Bought 2 and 1 was broken at the same ring.
    He sent me another for free and told me to keep the broken one. Otherwise all good. I like the lights and have had no other issues.
  9. Kyle_Bennett
    Kyle_Bennett El Chingón Staff Member
    50,513
    May 18, 1997
    Got 2 and mine have been perfect.
  10. Lateralus
    Lateralus More [H]uman than Human
    12,882
    Aug 7, 2004
    Well, you probably insert them straight in and out of your butthole instead of vigorously plunging them around like a farm girl churning butter. At this price point, I'm not sure that they are built for the latter. For that, one might want to step up to something like a Fenix or (for the more "experienced") one of those big MagLites.
  11. klank
    klank Killer of Killer NIC Threadz
    2,068
    Aug 22, 2011
    Bought two. Both units the zoom broke by getting stuck. Fixed them once but then it happened again so I said fuck it and left the focus where it broke.
    Both lights seem to have good battery life, I haven't charged them since I bought them. I only use them occasionally and for short duration.
    Overall they aren't bad, but the zoom is worthless.
  12. TypeO
    6,842
    Nov 1, 2000
    Obviously not on par with some of the more expensive lights but I also have a Thorfire C8s and it is a beast. For $19.99 from Amazon, it's awesome.
  13. HammerSandwich
    HammerSandwich [H]ard|Gawd
    1,041
    Nov 18, 2004
    I bought 4 in May. Zoom's not smooth in 2, but they all work. Actually, I gifted 3, so I think they still work. My keeper does.
    They're not amazing lights but definitely crazy good value. At this price, just buy an extra couple. If you need a reliable daily carry or glovebox light, spend more.
  14. Ducman69
    Ducman69 [H]ardForum Junkie
    10,467
    Jul 12, 2007
    Totally normal. The diode itself is square, so the light is square and crisp, but it diffuses as you adjust the focus into a round blurred light. The perfect square light projection is good for when you need to spot light something super far away, and believe me, that works.
    But it most certainly is BS on light output though.
  15. SixFootDuo
    SixFootDuo [H]ardness Supreme
    4,438
    Oct 5, 2004
    Ok I have bought several of these and can comment on the pros and cons.
    The short story is, the guy 2 houses down in a big time hunter / fisherman. He lives with one other guy and some woman that is always gone because she is a trucker.
    They hang out a lot in the back yard listening to classic rock and drinking beer. So I had one of these and was testing it out in my back yard in the dark when he yelled over and said, what the hell is so bright over there. I ended up selling him and and one other guy 2 of these flashlights I had just bought for $40 each. lol. They have a bunch of random friends over and I've sold maybe 5 other people these flashlights for $40 - 50 each. People love them.
    Ok, so there are a few big problems with this flashlight as I've had several.
    The focus ring is not well designed in that it does get stuck and won't focus. It's solid, but it does lock into one place from time to time. I found that holding the flashlight vertical and shaking it up and down "sometimes" works.
    The worst thing for me is that it's insanely bright ( a good thing ) but for only the first 5 or so minutes then it drops it's brightness level down ... substantially. BUT .... it's still bright. I'm guessing this has to do with the cheap batteries they sell.
    The Pros: It's very well built. The button does loosen up a bit if you use it a lot but still continues to work. My friend said you have to hit the button dead center after awhile but it does turn on. When new, the power button is sensitive and can be turned on with an off-center push.
    It's not small at all. While not huge it's easily the length of a cell phone, a larger one and pretty thick. It has a nice weight and solid feel to it. I was very pleased with that.
    It's cheap and it sells itself. I've made maybe around $400 dollars with only a $75 dollar investment.
    This does not come with batteries or a charger. I strongly suggest you buy 6 or 8 of these at least and then buy the chargers and 8 batteries. Your looking at $75 dollars or so BUT ... selling 2 of them gets all your money back and they sell pretty easy to friends and whomever.
  16. iRevert
    iRevert Limp Gawd
    275
    Jun 7, 2012
    What these lights have is a "zoomable" lens that allows you to change the throw. This is the zoomed in style and the "square" you're seeing is actually the LED diode as it is in the light.
    When you push the lens back to normal you get a nice normal flashlight, I own a few of the smaller "Ultrafire" 200lumen lights. For reference the switches are shit, the lumen output isn't what they claim, I doubt the LED diode is actually CREE but I haven't taken one apart to check yet. That being said for the price it's a decent light but nothing I'd trust my life to or trust enough for an emergency kit.
    For me it's good enough for the "Use so I don't step in dog shit at night" flashlight and I'm pretty happy with the smaller ones I have.
  17. fore1337
    fore1337 [H]ard|Gawd
    1,371
    Sep 28, 2004
    I got 3, gifted 2 of them.. and my only one just bit the dust about 2 weeks ago.
  18. TheOne&OnlyZeke
    TheOne&OnlyZeke 100% Irish
    9,387
    Jul 21, 2000
    Ah these only ship to the US. Wouldn't mind one or two.
  19. TechLarry
    28,017
    Aug 9, 2005
    They sure as hell ain't 2000 lumens
    I have a 500 lumen from walmart that blows it away.
  20. vibe
    vibe [H]ard|Gawd
    1,442
    Oct 27, 2005
    walmart listing?
    what's the best deal these days on 18650 rechargables
  21. vibe
    vibe [H]ard|Gawd
    1,442
    Oct 27, 2005
  22. TechLarry
    28,017
    Aug 9, 2005
    I'll have to get the name from the light (assuming I can find it LOL). I don't see the walmart listing, but then there are over 10 pages for "500 lumen"
  23. Cardio
    Cardio Limp Gawd
    260
    Jan 3, 2008
  24. vibe
    vibe [H]ard|Gawd
    1,442
    Oct 27, 2005
    can someone give me an idea about SAFE 18650 cells that are a deal?
    I read not to buy any 18650 cells that end in "-fire" (ha) despite the two for $9 deal the other day, so skipped those
    but now I need a couple and a charger - how much do I have to spend to get a decent set that won't burn my apartment down?
  25. ShepsCrook
    ShepsCrook [H]ardForum Junkie
    8,554
    Feb 16, 2003
  26. vibe
    vibe [H]ard|Gawd
    1,442
    Oct 27, 2005
  27. vibe
    vibe [H]ard|Gawd
    1,442
    Oct 27, 2005
    how about this 18650 deal - protected cells with a charger and about $41 if you use the subscribe and save
    https://www.amazon.com/EASTSHINE-E35-Protected-Rechargeable-Flashlight/dp/B0157XLN0A/
    fakespot gives the product and the company a grade A, which I have actually never seen an A before, so either good fake reviews or a good product?
    $20 a cell though, ouch
    oh wait, just the two batteries are $12.50
    https://www.amazon.com/gp/product/B0154NRFVE/
    can I get a cheaper charger that's safe enough?
    oh wait, the two batteries get a fakespot grade F - wtf is up with that
  28. vibe
    vibe [H]ard|Gawd
    1,442
    Oct 27, 2005
    oh wow, I tried the $9 for two thorfire with charger off amazon (use the coupon code at bottom of the page)
    these 18650 flashlights are amazing
    blows the free Harbor Freight flashlights out of the water
    I wish there was an "extra low" mode though so the runtime is several hours (I know it has like a 2-hour low mode)
  29. griff30
    griff30 I Lower the Boom!
    8,510
    Jul 15, 2000
    I need those flashlights with the sharp teeth.
    It's a breech light. If you're a tactical operator you need them.
    :hilarious:
  30. Staples
    Staples [H]ardness Supreme
    7,542
    Jul 18, 2001
    Does that mean the teeth are for stabbing people?
    griff30 likes this.
  31. griff30
    8,510
    Jul 15, 2000
    They started making those flashlights to look like breach muzzle flash hiders to make them look "tacticool".
    A Breach flash hider for shotguns has that "tooth" look to them. That way the muzzle can be placed on a locked doorknob and fired so gases can escape the sides while allowing the slug to blow the doorknob out the other side, thus you gain entry.
    The firearm community started using that look on everything, including flashlights, to look "tactical".
    Its like putting a picatinny rail on every damn surface of a gun, its for looks and it can get out of hand.
    I definitely want this light though.
    Good value.
  32. vibe
    vibe [H]ard|Gawd
    1,442
    Oct 27, 2005
    I've become a fan of this $2.50 model with the red ring in the front, because the ring glows, which makes it great for lighting up the front of the bicycle to the sides and bottom, which a regular 18650 light does not do and is pitch black to the sides:
    http://www.ebay.com/itm/322058303093?var=510990823184
    there is a $2.60 model with five modes too but I like not having to constantly cycle though all the diffferent modes
    http://www.ebay.com/itm/201558345575
    holds a protected length battery just fine
    the lumens claims are getting way out of hand, no way any of these are 3000, 4000 and definitely not 6000
    some other sellers are only claiming 270LM for the same bulb and battery which is ten percent
    if anyone knows of another model with a glow ring, please let me know?
  33. doz
    doz [H]ardness Supreme
    5,547
    Jun 16, 2009
  34. mope54
    mope54 [H]ardness Supreme
    7,089
    Oct 2, 2004
    I bought this Opus BT-C3100 http://www.gearbest.com/chargers/pp_174044.html? after reading quite a few threads on candlepowerforums (and another site, budgetlightingforum) for inexpensive but reliable (and safe) chargers. I needed to regularly charge a half dozen D cell batteries when my daughter was born so I bought a couple adapters but they took too long. I eventually ended up buying a Maha for around $100 but the year or so I used the Opus it was excellent.
    I still have the Opus sitting on the shelf in my office but haven't really had a use for it for a while.
    Those two sites I referenced will have copious amounts of info regarding battery selection, too.
  35. doz
    5,547
    Jun 16, 2009
    Well, I got refunded after 20 days of no shipment.
    Ridiculous. And Ebay protects the seller by not allowing me to leave feedback. Dumb as fuck.
  36. vibe
    vibe [H]ard|Gawd
    1,442
    Oct 27, 2005
    stuff from china during xmas can take like 25+ days to show up - it might still appear
    but these days there are a ton of other T6 18650 flashlights on ebay that are better deals than the original post in this thread
