Ultra X2 X-Connect modular review
Yeah, those are the X-Finity series PSU's. I'm not sure if the internals/guts are the same though. Maybe someone has some insite on that?
I currently have a Vantec Stealth 520A . It's a great PSU, only problem is its too big for my mid-tower plexi case. I can't mount a fan in the top blow-hole as the PSU, with all its connected cabling, is in the way. I've been waiting to pick-up a decent modular replacment that's a little smaller, so I can clean up the cabling mess.
I was on the Antec Smartpower 2.0 500W hunt, but since I have a plexi-box I'm wanting something with a little more bling factor. I heard back in Sept/Oct that they had a 2nd gen on it's way that would support dual rails, and use the Flex-Force cabling for the modular connections. I've seen/read/heard all the mixed reviews for the 1st gen, but I figured I'd wait to buy a new PSU until someone had a chance to check one of the 2nd gens out.
I have a Ultra X-Connect and it work great no problems after 1 year of heavy use
Thanks for the reply jonnyG! I was actually hoping you had somethig in the works. :D
It was you who I read that mentioned an upcoming 2nd gen, so I've been waiting for its release. Now that X-mas is here, and my G/F's PSU fan is dying, I'm heading out to Fry's on Friday to see if they have 1 in stock. Outpost has'em for $89.99, so I may get lucky. ( My G/F will get the "hand-me-down" Vantec ) :p
w00t!
Picked it up today. $99 at the local Fry's, but I think it'll be worth the investment. Definitely looks WAY better than the VANTEC. I'll post a pic a little later, when I can track down where my G/F put the digi-cam.
:D
