Hey all.
I'd like to put together a small home Linux server that will be on 24/7 and mostly serve light duty; lightweight web server, non-transcoding PLEX server, an Asterisk voip gateway for a couple of vintage phones, a few other things. And then a small-ish game server that complicates things a bit.
Thus, here's where I have two competing priorities and I'd like to ask for any suggestions, ideas, or creative alternatives.
(1) Ultra Low Idle Power - The lower the better. <10 watts idlea would be ideal. I currently live in Hawaii, and one of the costs of paradise is extreme electricity prices. Generally about 0.30-0.35 per kWh, but rates can flirt with 0.50 per kWh during peak times. Yeah, I know -- holy moley. Can't just leave a big bad beast on all the time like I did in the Midwest.
(2) Game Server - I would like to host a couple of persistant private games for a group of friends (say, 8-10 players), notably Ark: Survival Evolved and 7 Days to Die. These aren't terribly well multi-threaded and definitely benefit from high single-core performance and high TDP parts.
If it were just #1, I'd look at simply getting something like an efficient Atom CPU / mobo combo and a pico psu, or any number of small-form-factor solutions. My PLEX drives are in a separate USB housing that can be turned off to save power when unused, and the server will likely just have one SSD or M.2 drive. No need for non-integrated graphics.
#2 really breaks the ultra-low-power, but I have have a feeling Ark in particular will choke on a low-end CPU. What is sufficient for hosting 8-10 players without stutter, etc? A Celeron? A E3-1200 series Xeon? An i3 (particularly the new coffee lake 8100)? Any of the new Ryzens?
I don't really have much feel, particularly for the integrated-type processors. I generally only follow the high-end, newer CPUs for multi-core rendering & encoding performance.
Ideally, compromise would be < 30 watts idle, and I'm not particularly concerned about consumption under load when many people are playing. Are there perhaps any [readily available] laptop-targeted CPUs that would do the trick? (E.g., great frequency scaling and energy efficiency, but decent performance under load.) Ideas / recommendations please!
I have a target of around $300 as I already have 16Gb (2x8G) of full-size DDR3 and 32Gb (2x16G) of full-size DDR4 currently sitting unused. (Solution recommendations that use SODIMMs are still welcome, but I'd have to adjust budget.)
Thank you in advance --
