So a few nights ago I was bored running a server 24/7 @ idle most of the time so I decided to set up a image hosting site based on CeleronDude's Uploader script. I set it up with
Apache 2.2
PHP 5.2.0
Uploder 6.1
After a few problems it seemed all good until I realised that bandwith monitoring wasn't working.
After a bit of research I found that a module called mod_rewrite needs to be enabled for bandwith monitoring to work, I added the below code to .htaccess in \htdocs\files
Is this right? Why isn't it working? Did I miss something out?
FYI: The site is www.robouploader.co.nr
Thanks for any help.
EDIT : Updated Apache and PHP.
Apache 2.2
PHP 5.2.0
Uploder 6.1
Code:
# Disable listing of user files
DirectoryIndex index.php
Options -Indexes
# Disable php in userfiles directory (recommended!!!!)
RemoveType php
<IfModule mod_php4.c>
php_flag engine 0
</IfModule>
<IfModule mod_php5.c>
php_flag engine 0
</IfModule>
# GET requests only
<LimitExcept GET>
Order Allow,Deny
</LimitExcept>
# This file MUST be in the user files directory in order for bandwidth tracking to work.
# Bandwidth tracking requires your server to have the mod_rewrite module enabled. If you do not have it,
# you will probably get some Internal Server Error messages.
# To disable bandwidth tracking, comment out the lines below that start with Rewrite...or delete everything from here (this line).
# The file.php path MUST be correct in order for bandwidth tracking to work correctly.
# You can use either relative or absolute path. If none works try entering the FULL url
# to file.php as in this example below:
# EXAMPLE ONLY:
# Turn on mod_rewrite
RewriteEngine on
# Edit the path to tracker in the line below (the default setting should work
# unless you've changed the path to the userfiles directory.
RewriteRule ^([0-9]+)/(.+)$ http://robo.webhop.biz/file.php?userid=$1&file=$2 [L,NC]
# This is the default value in case you messed up and forgot what it looks like.
# DO NOT change this, copy it to another line, uncomment it and edit it there so you'll always have this.
# DEFAULT CONFIG: RewriteRule ^([0-9]+)/(.+)$ ../file.php?userid=$1&file=$2 [L,NC]
