apt-get install gcc
BillLeeLee said:Ubuntu doesn't come with gcc installed by default.
Code:apt-get install gcc
pulls in gcc4, version 4.0.3 I believe. If you need a gcc3 install, there is gcc-3.4, gcc-3.3.
Besides using apt-cache search, you can also check out the ubuntu package list.
http://packages.ubuntu.com
sudo aptitude install build-essential
As I Lay Dying said:Code:sudo aptitude install build-essential
this will download the necessary compilers/lib etc etc etc.
