QwertyJuan
- Aug 17, 2000
I am needing another AP and wondering if I should get an AC or stick with the Pro? Thoughts??
Thanks!
Thanks!
They are nice, and fast, if you actually have a use for AC (or plan on it). If you have a device that you transfer files to/from that can't be plugged into ethernet because of location or you have 150mbps+ internet it could be worth it.
I just can't justify the cost of the WAP's because I have ethernet everywhere. Then there is the additional cost of the adapter cards also. If I need to transfer files the laptop gets plugged in.
If its for your house and you only need 1 its safe other than that is not ready for prime time in a corp install.
The Pro's radio output on 5Ghz is almost 1/3rd the power output of the AC model.
So the range on 5Ghz is shorter on the pro....which is why I purchased the AC model.
The std and LR models do not possess a 5Ghz radio.
But yes... the AC model's firmware is still baking.
Getting better, but still being worked on. There are 3 major bugs left on the AC model that need to be resolved before I would call it enterprise ready.
I have a UNIFI-AC version 1. There is a version 2 but I don't have it.
It worked fine with less than 4 clients connected using firmware 2.5.4
Once I added more clients it started dropping connectivity every 2-5 minutes
In the beta section of the UNIFI forum firmware 3.2.9 is soaking for GA status.
That firmware and controller update has a boatload of UNIFI-AC fixes.
I've only been running the new code for 3 days now, but there have been no dropouts or restarted with 7 clients connected.
For me it's a major improvement.... Meriki just sent me a AP with a free 3 year cloud license. So I'll eventually be running and testing both...just to see how each compare.
I had the same issue with the one I got when they released them and had the Competitive upgrade promo going. Had to RMA it as no released FW made an appreciable difference. The replacement has been rock steady in the Home environment I placed it in. 4 SSID's and about 20 WiFi devices over both bands. Migrated from 2.5.x to 3 different FWs in the 3.x range without a hiccup since. I agree though, there are a few big issues and missing features before it's ready for as wide of a deployment as the original classic UniFi.
(2) regressions found in the 3.2.9 code.
They expect to be making 3.2.10 available on the beta site this upcoming Monday as pending GA for another 2 weeks. (just in case they missed something)
THEN there should only be 3 major bugs left on the AC models.
FYI ZH not working is 1 of those three three remaining major issues.
Had a Pro, upgraded to an AC in a busy home environment (10-15 devices per AP all the time).
The AC v2 has been rock solid for the last few months. Great range and speed. 5ghz is noticeably better than on the pro as far as range.
For reference I also have a UAP, UAP-LR, and UAP-PRO.
Thinking about meeting half-way and go with the UAP-Pro. Don't really need the AC speeds since I have Ethernet throughout the house.
It's not that it's not stable at this point, the firmwares just aren't near as fleshed out as the earlier generations. It was obviously rushed to market, and the early adopters will/have paid the price. I hope this doesn't signal a trend with UBNT.
It's sad that the AC has been out for what... 2 years?? And it's still not stable?
Thanks for the feedback, ended up ordering a UAP-Pro. Should be enough for a town house.
Just want it for the numerous phones/tablets and 2 laptops in the house. Rest is hardwired.
