Hello!
I'm redoing my network and can't decide on which router to pick... Currently I'm choosing between Edgerouter lite and RB750GL.
My WAN connection is 100/100MBit and 1GBit local network. I plan on having 2 vlan-s, home vlan, DMZ vlan with ESXi virtualized servers and SAN/NAS and maby a third vlan for lab/testing.
I'm quite familiar with the Mikrotik since I use it on a few sites and have good experience with it. Also, user base is quite big, forums are really active and there is a lot of examples available on the web.
I know EdgeRouter is not as easy to setup as Mikrotik, but I'm familiar with linux and have quite some experience with pfSense and Cisco equipment, so I shouldn't have much troubles setting it up. How is the documentation on the EdgeRouter side?
I would like to go with Edgerouter since it's more powerful, but there have been some memory problems at the beginning when it was introduces.
Has that been fixed by now?
Does anyone use cacti or munin to monitor the router?
Are there any scripts out there for monitoring?
Has it been stable for you?
If I export the configuration, is it exported as text file or a binary file?
How's the support on the forums?
What would you choose and why?
Matej
Matej
