Two-Thirds Of Early Tesla Model S Drivetrains May Fail By 60K Miles
Discussion in 'HardForum Tech News' started by HardOCP News, Dec 10, 2015.
  1. HardOCP News
    HardOCP News [H] News
    0
    Dec 31, 1969
    Tesla Model S owners better hope that this article is wrong. Could you imagine having to replace the drivetrain on a Tesla after only sixty thousand miles?
    Survey data collected by Plug-In America from current early-model Tesla Model S owners has predicted that up to two-thirds of early model electric-drive units may fail by 60,000 miles. If their predictions are even remotely accurate, that’s bad news. As reported by Green Car Reports, the sample data was run twice with the information they collected from early Model S owners.
  2. daglesj
    daglesj [H]ardness Supreme
    5,082
    May 7, 2005
    60000? I do around 5000 a year so that would kind of work for me.
  3. lucidrenegade
    lucidrenegade Limp Gawd
    387
    Nov 3, 2011
    Tesla seems to be good about taking care of their customers, so I'd assume they'd replace them at no charge if it is truly a widespread problem.
  4. Time2Kill
    Time2Kill [H]ard|Gawd
    1,152
    Jul 10, 2005
    Until you go to resell it and it has no value because the next owner will need to replace it.
  5. Tzzird
    Tzzird [H]ardness Supreme
    5,891
    May 9, 2006
    Better to drive it 60,000 in 6 years and hopes that it breaks before the end of the 8 year warranty for the drivetrain.
  6. Spidey329
    Spidey329 [H]ardForum Junkie
    8,677
    Dec 15, 2003
    I'm guessing Tesla will replace them when they fail. The iterate-fast (fast prototyping) approach often causes this to happen and it's usually in the companies best interest to handle it appropriately. The ModelS line had a ton of new designs to the drive-train including custom motors.
    Plus, the drive-train in an electric vehicle sounds worse than it is. It's literally an electric motor or two. They don't have a ton of other components typical cars have, and this repair can probably be done in a matter of hours. As long as it's not the battery, I don't think Tesla will see it hit them too hard.
  7. schizrade
    schizrade [H]ardness Supreme
    4,725
    Feb 15, 2003
    This x1000. Direct drive motor in the wheels. Half a day tops.
  8. britjh22
    britjh22 Limp Gawd
    383
    Oct 15, 2014
    The title is a bit click baity. Tesla says the earliest drive trains are less reliable than newer, no big surprise, I'm sure they are learning a lot about their own product. Also, an 8 year/125,000 Mile warranty is nothing to snuff at. The biggest thing we are missing is cost of replacement. I would not be surprised to hear that it is much cheaper than the costs associated with competing vehicles (engine/trans/fueling/etc.).
  9. Elios
    Elios [H]ardness Supreme
    7,207
    Aug 12, 2004
    like to know what they expect to fail.. its a motor and a reduction gear are they counting the battery?
  10. OEM
    OEM [H]ard as it Gets
    20,123
    Jun 15, 2005
    Even if it were the battery, cost aside, the labor to do it and physical time would be mere hours.
  11. Elios
    7,207
    Aug 12, 2004
    if that Tesla has shown they can swap a battery in under 4 min
  12. xaustinx
    xaustinx [H]Lite
    70
    Aug 4, 2004
    8 year/infinite mile warranty; FTFY
    https://www.teslamotors.com/blog/infinite-mile-warranty
  13. MoFoQ
    MoFoQ Gawd
    840
    Sep 18, 2002
    it is jalopnik after all
  14. Glyphic
    Glyphic [H]ard|Gawd
    1,625
    Apr 19, 2004
    This article and headline are stupid. 2/3 of 350 something cars that were actually surveyed. Not only that but it doesn't even account for the actual reasons any service was done.
  15. SLee
    SLee Gawd
    955
    Oct 27, 2002
    That's a reasonably large sample. Large enough to confirm that the Model S's drive unit is much less reliable than practically any engine/transmission found on any other vehicle on the market today.
    And besides there are only two reasons why the drive units are replaced, they have failed or have developed noises that are indicative of failure.
  16. Burticus
    Burticus 2[H]4U
    3,900
    Nov 7, 2005
  17. britjh22
    britjh22 Limp Gawd
    383
    Oct 15, 2014
    I think this statement isn't really that useful. From what I can tell the maintenance schedule for the Model S, where it relates to the actual drivetrain, is very minimal. Imagine getting 60,000 miles out of a Mercedes S Class without any direct maintenance on the engine/transmission, that would be a more useful discussion point. I'd love to see what the reliability is on a Mercedes V8 without any direct maintenance for 60,000 miles, I'm guessing it will be lower then the Tesla.
    Also, with an electric engine, replacement is likely the most efficient method of repair/maintenace. Instead of having to chase down an issue, they just replace it (under warranty, and a fairly quick procedure), and likely send it back to the factory to be refurbished.
  18. groebuck
    groebuck 2[H]4U
    2,446
    Mar 9, 2000
    Someone did a web page comparing buying a model s to getting a Honda Odesssy van. http://www.teslacost.com/the-model
    Turns out it was about 600 a year cheaper to get the Honda (and that was calculated at 4 dollars a gallon...given gas prices I am guessing it would be even more). That does not factor in the coolness of driving a model s versus a mini van...
  19. daglesj
    5,082
    May 7, 2005
    Always owned a car till the end. Never sold one on. My last one wast worth about £400 by the time I traded it in for scrap with just 40000 on the clock.
  20. lostinseganet
    lostinseganet [H]ard|Gawd
    1,133
    Oct 8, 2008
    What about the batteries that died wif you did not use the car for 3 months. When people learned about that tesla said in screw you at first. Then came the outrage and they backed down...Same could happen here
