Two fans on the GeminII, Only one fan slot on side panel.
I'm noticing that there's about a 3-4 degree difference in CPU temps when I have my case side panel on vs the case side panel off. So my best guess is that there isn't enough air being fed into the two 120mm Yate Loons @47cfm.
So my main concern is, since there is only one fan opening on my current side panel, do I need to attach a side fan that is providing more cfm to compensate for the two lower cfm fans attached to the Gemin II, or will another 120mm Yate Loon @ 47cfm be sufficient enough?
Any help will be greatly appreciated. Thank You.
