I don't think AMD is supporting this at all. They aren't smart enough to do a guerilla marketing type of thing like this. I wish they were, but...
\Edit, Aww i just read that people trying this seems to have problems having it 100% prime/ibt stable :*(
I am using Biostar 790GX A2+ mobo. Some said it only works on Biostar motherboards.
Forget about the good old days of the Celeron 300a overclocking to 450 MHz. That's doggy doodoo compared to what AMD has given us today!
Is there no one with a Kuma and a 780GX board around here?!
I know there is at least two with the mATX DFI 780GX + 750SB board with Kumas here.
The guys over at OCN are having a pretty lengthy discussion about this, and why it may work BETTER in the future.
Since the current fabs use defective quad cores to produce tri cores, once the fab process matures, there will be less and less defective processors, BUT there will continue to be demand for tri/dual cores, meaning they will disable perfectly working quads into tri's or duals, to continue making money, since it is virtually the same price to create a tri core as it is a quad core.
Kuma core is PH1 B3 core and maybe is laser cur, IDK, but I know that when I had ACC set on both Auto and 4 cores I only had 2 cores running, but I will try it again tommorrow using the 4 core setting and all the percentage ACC values in ACC. It doesn't/won't work I bet, and if it did work on the PH1 B3 cores then why hasn't anyone stumbled across this amongst all the owners of Tri Core PH1's, and the answer is that enabling ACC for all cores doesn't work on PH1 B3 or B2 cores.
PS: I was going to do this earlier but I had to eat and am now defragging my very fragmented HD and also me own HD known as me little brain, IOTW, I am going to catch a few ZZZZ's and then go to work and then I will try it for you and myself.
Tested & works on:
- ASRock AOD790GX/128M
- BIOSTAR TFORCE TA790GX 128M
Tested and doesn't work on:
- Any Asus mobo due to heavy BIOS customisation (personaly tested on ASUS M4A79T Deluxe, M3A78-T, M3A78 Pro, works on none of them, that's were my BIOS assumption comes from)
Would like to know about :
- MSI K9A2 Platinum
That sir, is a ballzy assertion.
The 50% OC as often as 300A's did vs hit and miss 4th core abilities.... Hell, the 1ghz to 1400Mhz Thunderbird OC's were more impressive than this. This is more like the geforcefx 5900 to 5950 softmod of 2004. ie, the product is the lesser than the competition anyway, and the mod is less than 50% successfully stable. Maybe it will become common place as the yields improve. Maybe not.
Maybe I'm just feeling nostalgic since I found my old BP6 the other day, stored in my closet.
Either way, If I had one, I'd be unlocking it.
Lol i love how you are greated by a I7 Fail Avatar.
haha I still have my old BP6 dual proc board as well. With two 300A's on it no less, I just cant bring myself to throw it away!![]()
Interesting mod, but isn't there a reason as to why AMD shut that CPU off? Chances are it didn't pass QA testing. Just a thought though.
If AMD was really smart, what they would do is make a true black box processor (completely untested, shipped as a fully unlocked quad with at least 2 cores working at 1 ghz, then it is up to the user to test stability of the cores and max speed - if they could sell these for $100 to $125 range enthusiasts would gobble them up as long as the yields weren't too terrible - they would have to have a no return policy though.
As yield increases, prices will decrease (less waste) and so they might eliminate the need for tri-core processors.The guys over at OCN are having a pretty lengthy discussion about this, and why it may work BETTER in the future.
