Turn off another PC, when I turn off my main PC
M76
[H]ardForum Junkie
I've been trying to get my W10 to automatically turn off another W10 on the local network when I turn it off, but so far nothing worked.
I've tried
gpedit.msc (local Policies)
Computer Configuration -> Windows settings -> Scripts -> Shutdown -> Properties -> Add
But the command I entered does not execute, or has no effect.
"C:\Windows\System32\shutdown.exe /m \\compname /s /t 5"
Tried the same thing with the task scheduler:
Begin the task: On an event
Log: System
Source: USER32
EventID: 1074
again nothing happens on shutdown, the other PC keeps running.
If I issue the command directly it shuts down the other pc.
B00nie
[H]ardness Supreme
Try adding a ping script to the shutdown and see if even that gets through to the other workstation
dbwillis
[H]ardness Supreme
wont you need to connect to the other PC with an administrative account? and that needs to have a password I assume.
try shutgui.exe (download it) and once you get that working, then you can script it to work with tasks
