Lord of Shadows
- Mar 9, 2004
I've been neglecting my water cooling system the last couple years and havent changed the water as often as I'd like. But my system has never leaked once, I wanted to replace all my tubes and maybe even my clamps and T line so everything is new and pretty in my new system. -- But I dont think I will be buying that water block just yet cause I may need to completely rethink my loop layout.
tubing -- Supposedly the clouding is caused by 'plasticizer' which keeps the tube flexible. I always used distilled water and hydrix (although like I said that water was in for a year or so old. But I did run clean distilled water before taking it out, tubing still stained, supposedly I could pipe clean it, but Id rather just run new hose)
Here are my routing problems: (6970 is too long) -- I'll stick with air for the time being.
pump1
pump2
Things to note:
* Always be patient and let things dry if they get wet.
* Plastic hose clamps are awesome
* You wont have problems if you engineer things correctly.
* You will need to top off / replace water more often than you actually will
pump1
pump2
Things to note:
