Tube res that my D5 pump can mount to?
Discussion in 'Water Cooling' started by newls1, Sep 2, 2018.
  1. newls1
    newls1 2[H]4U
    3,761
    Sep 8, 2003
    Is there a tube res out in the watercooling world that a D5 pump can install to for 2 reasons that im trying to meet? 1) less tube needed, and 2) will save me a ton of space. I have 2 loops and tired of using my dual bay res'es as they take up so much space... really want to switch up to a big tube res that my D5 can mount on the bottom of. Thanks
  2. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    25,273
    Oct 29, 2000
    You can do this with pretty much any reservoir using a G1/4 male to male adapter.
    cyberguyz likes this.
  3. cyberguyz
    cyberguyz Limp Gawd
    479
    Aug 28, 2014
    That would work as long as you are not standing it up on end - a position most will use due to lack of horizontal real estate in an average case. You need something a little more structurally sound than a G1/4 M->M adapter for that.
    But if you have the horizontal space to lay it down, that would work great and be a lot cheaper.
  4. newls1
    newls1 2[H]4U
    3,761
    Sep 8, 2003
    DedEmbryonicCe11 likes this.
