Tty.c: loadable library and perl binaries are mismatched
Discussion in 'SSDs & Data Storage' started by N Bates, May 14, 2018.
  1. N Bates
    N Bates [H]Lite
    100
    Jul 15, 2017
    Any idea why I get the below when I use Napp-it on Omnios after updating omniosce from 151024 to 151026?
    Do I need to update Napp-it now ffor it to work?
    Tty.c: loadable library and perl binaries are mismatched (got handshake key 9e00080, needed 9e40080)
  2. _Gea
    _Gea 2[H]4U
    3,774
    Dec 5, 2010
    napp-it supports OmniOS 151026 up from v18.01 (Apr.02).
    So download the newest in menu About > Update
    After the update you must re-login into napp-it.
    If error persists, re-download a second time.
    https://napp-it.org/downloads/changelog.html
  3. N Bates
    N Bates [H]Lite
    100
    Jul 15, 2017
    Thank you _Gea, I will do just that, thanks for all your help.
