Tt Water 3.0 Riing 360 AIO - Use factory applied paste or replace ?
Discussion in 'Overclocking & Cooling' started by trilegdog, Apr 8, 2016.
  1. trilegdog
    trilegdog [H]Lite
    67
    Nov 30, 2007
    New build. Thermaltake Water 3.0 Riing 360 RGB AIO. Ordered Noctua NT-H1 Thermal Compound for the install, but now see that there is already factory applied paste. Should I replace it with the NT-H1 or use factory? Nothing in the AIO install instructions covers thermal paste. Thanks
  2. trilegdog
    trilegdog [H]Lite
    67
    Nov 30, 2007
    Update: I used Arctic Silver Arcticlean Thermal material Remover & Surface Purifier to remove the factory applied thermal pad (coffee filters for the lint-free rag). Applied a pea sized amount of NT-H1. Idle temp shows in UEFI as 29C, so it looks normal so far.
  3. primetime
    primetime [H]ardness Supreme
    5,502
    Aug 17, 2005
    it actually had a thermal pad? probably was a decent idea redoing then.
    trilegdog likes this.
