To give you some bearing.
I got my mobo about 1 year ago, but I have always had trouble installing XP and have neglected my system for to long.
I can't do a traditional install (ie, boot with the CD and go from there with a blank HDD) I have to already have an working install of any windows OS to install pro, by going through the cd menu and choosing my partition to install to. I don't end up with any problems as it's as good as a traditional install. However it does become painful when you forget about that stupid message that goes nowhere and why you have to do it from the cd menu
This message comes after it has done the first scan, and it obviously can't find the CD rom, or load drivers for it, so it scans mechanism 2, and just sits there indefinately, The computer doesn't freeze, but all you can do is reboot.
I am running an MSI K7N2 Delta-ILSR, WD 400JB, on CD rom (LG RW) on primary EIDE set as primary.
Now I have never been able to get past this point. I use my WIN98SE startup disk as i have extra tools that I like to use for dos, but that shouldn't make a difference.
The problem as you can see is that of loading DOS CD Rom drivers so it can read the CD.
Making a WINXP startup disk and booting doesn't work either.
I am stumped, it's a really obscure parsed message, any help with this will be appreciated.
