elite.mafia
- Aug 23, 2004
Hey guys. So I have a old p4 3.0ghz Northwood system with a Radeon HD3650 (AGP) card that I'm trying to install windows 7 32 bit to. First I tried to install it via USB, but kept running into issues trying to boot to the USB drive. So I gave up on that and decided to try installing the OS with another system, used sysprep with generalize and tried to stick it in the other system. I have Windows 10 64 bit installed on 1 partition and windows 7 32 bit on a seperate partition (I did it like this because I just wanted to see how this system would perform with an SSD. I don't have any extra SSD's to do this with so I thought using a partition would work) I'm assuming this is incompatible? When it boots up, I see the choice for Windows 7 and Windows 10. It doesn't matter which I pick, both boot straight into the 64bit Windows 10 install.
I'm guessing at this point my best option is to either use a dedicated drive and try again, or to try and find a DVD-R and install it directly to the P4 system. Does anyone have any work arounds?
