I have a Zalman Z12 case and my video card has always run on the warm side. It came with a 120mm intake on the front and a 120mm exhaust on the rear, they both ran around 1000rpm.
I got some fans to try and improve airflow (not the greatest fans but they were free).
(1) 120mm 3 pin 1600rpm 63cfm Scythe S-Flex
(2) 120mm pwm 1500rpm 63cfm Rosewill RWC-1612
(1) 140mm pwm 1300rpm 89cfm Rosewill Hyperborea
My case has two top fan mounts, 1 rear fan mount, 1 bottom fan mount, 1 front fan mount, and empty 5.25 bays. They are all 120/140mm except the rear is 120mm only. The top and front are mesh and the entire front has dust filtration. I have a Thermalright tower cooler with a single 120mm pwm 1300rpm 58cfm Thermalright fan.
I put the 120mm Scythe on the rear as exhaust, the 120mm Rosewills on the bottom and front as intakes, and the 140mm Rosewill in the 5.25 bays as intake. At full speed the fans are moving a decent amount of air and I thought this would give me lots of positive pressure. I can feel air blowing out the back of the case below the video card (the pci slot covers and the area next to it are mesh). The confusing part to me is air is being pulled into the case through the top fan mounts. Not a lot but if you hold a piece of paper just over the mesh it will get sucked down. This is with all fans on full when running P95. If I limit the exhaust fan a little bit the top opening appears to be neutral.
The case is not great for airflow. The front intake was ridiculously restricted. Air goes through the front mesh, then a thin airy sponge like filter, then a plastic dust filter, then honeycomb mesh before it reached the fan. After the fan it goes through honeycomb mesh twice more (HDD bay, at least they are mesh instead of solid) then it was blocked by a solid piece of plastic that would snap the HDDs in place so they could be tool less. I removed the plastic filter and cut out the honeycomb mesh in front of the fan. I also removed the plastic tool less HDD thing since it also has a place to just use a thumbscrew instead. The buttom PSU intake seems even more restrictive, so much so that it seems almost useless.
My next adjustment will be mounting the PSU fan up. I think I will swap the Scythe and 120mm Rosewill as well to get more intake to counter the PSU exhausting case air.
