Shadowhaxor
- Jul 15, 2005
I'm trying to indentify and issue with my 10/100MB Lan. I noticed for a while that my transfer speeds from my ESXi server and my FreeNAS server were crawling at 3-5MB/s, however I always regarded it due to the crappy FreeNas box I had built. I recently upgraded to a Synology DS212 and popped in 2 1TB drives until I could get my 3TB drives from newegg.
However after making a LUN for the ESXi server and a volume for CiFS I noticed that I see g the same pitiful file transfer speeds. My initial thought was my network however everything on the LAN is wired except for the Android tablets which are wireless but they also are not a factor in this issue.
Now I've done several tests to eliminate the cause here;
1. I transferred a 8GB ISO from the Blurays I ripped from my 1 PC to another. They are connected via 2 switches as they are on the other side house from each other. Now when the file transfers I get 11MB/S which comes out to 88Mb/s, which is close to the max throughput of the 100mb/s. That transfer took 6-7 minutes or little over 1GB per minute.
2. Transfer from PC to DS212. I took that same file and transferred it over to the DS212 and i'm getting the same speed, which is 11MB/s. So I'm not seeing a network related issue thus far.
3. Transfers from PC to ESXi 5 hosted guest. This is where I see the issue. Transferring from either the PC or the DS212 to a ESXi 5 guest, the transfers are halved or worse. At one point I saw speeds from 9MB/S but they dropped to 3-5MB/S. Every other transfer since then has also been as slow.
The guest is hosted on a Supermicro server with 8GB of memory and (2) Quad core xeons. So I'm at the point where I believe that the speeds issues are either a combo of the (2) NIC's (Onboard Intel 80003ES2LAN Gigabit) on the server or a configuration issue. However I've verified that both the main and standby adaptor on the server are running at 100mb ( changed it from auto-negotiate for testing) and the speeds still don't change.
I've made several changes to the Win2k8 server network such as disabling Chimney, QoS and dropping the Anti-virus for testing in case it was inspecting my network traffic, still no change. I also checked the ESXi network performance and it's not even close to peaking, max usage is 9800Kbps which is just about 10Mb/s.
Going crazy here trying to figure out what may be happening and it's likely in that I've probably missed something silly.
Any ideas?
Any ideas?
