Just a quick question. I'm trying to get a device that I can run a CAT6 cable to from my Motorola Modem/Router Combo through the basement and hook into in a room across the house because my WIFI doesn't extend to my master bedroom on the second floor well. I don't want a WIFI extender because I read that it just picks up on your current WIFI and extends it farther but at it's degraded rate. I want a WIFI access point (I think that is what it is called) where I can hook the CAT6 cable into and then project WIFI on the other side of the home plus the upstairs, but I don't want a second username and password like I would get by buying a second router. Will the product below allow me to do this?
http://www.amazon.com/TP-LINK-TL-WA...194486_1_1?s=pc&ie=UTF8&qid=1414294134&sr=1-1
I prefer something cheap and easy to set up which the Ubiquiti Networks UniFi AP Enterprise WiFi System seems like it may be a difficult set up. Thanks for any help.
