hardware_failure
- Mar 21, 2008
Im trying to compact a very large dynamically expanding VHDX file. On the first try It did compact a little bit, but not anywhere near to the size of the actual data (3.4 TB used of about 7TB, now the file is about 5.5TB)
After some reading I learned that the VHDX will only compact down to the last area that data is stored, just like trying to shrink a partition. Makes sense. So I did a complete defrag (took over a week) but Im still having the same problem because...
There is a large MFT "area" about 3/4 into the VHDX file. Defraging software wont move it. I read that some sort of boot into defrag might do it, but the problem is, this is a production server and it cant be down for more than the weekend. Just analyzing the volume takes for freaking ever. I do of course have solid backups of the system, but that in it self is the whole reason for this. I would much rather back up 3.4TB worth of data vs 5.5ish.
Long story shrot - is there a quick, easy and SAFE way to move an MFT on a VHDX file?
Thanks.
Thanks.
