Hi everyone
My old GPU was a Radeon 6850 and upgraded to a Sapphire Tri-X R9 290 last night.
Upon installation, there is no video output through DVI or HDMI I can not get to Windows or even see any start-up screen at all.
My motherboard is a MSI P67A-C45.
My power supply is an OCZ700MXSP
Processor: 2500K
Ram: 8 GB (4x2)
The power is hooked up to the R9 correctly (1 6-pin and 1 6+2 pin). All the fans on the GPU spin too.
I tried uninstalling the old ATI software/drivers and putting in the new card; same thing.
Put back in the Radeon 6850 and it has fine output
I did the motherboard BIOS update through MSI Live and it says it installed it, but i have doubts. My next thing to do is try to update the bios manually
After that....no idea
I do not have another power supply I can try (only a 350 watt one)
I do not have another PCI-express slot i can try
I do not have another computer I can try.
This morning I looked at it again; usually Windows 8.1 upon loading, before entering the password for my computer, the internet would connect. The USB wireless adapter has no green light, so I am assuming it does not even get that far with the new GPU installed. Maybe it is stuck somewhere in BIOS and wont go past it?
Installing the old GPU once again works fine. Any ideas?
I am running out besides updating the BIOS manually.
Processor: 2500K
Ram: 8 GB (4x2)
