Troubleshooting analog audio on ASUS P8Z77
threnk
Hi All -
So, I have an ASUS P8Z77 mobo that's, otherwise functioning perfectly. However the analog audio out from the front of my case (and directly from the mobo, as well) is not functioning.
The HD Audio is certainly hooked up properly to the mobo, and I've installed the most recent drivers. (I'm on windows 10).
I have a GPU (NVidia 570) that is hooked up to my monitor via HDMI. As far as I can tell, the computer is sending the audio through the HDMI.
Additionally, it seems to not detect when I plug in my headphones from either analog jack (front or rear port).
Please help!
Do you have the Realtek® ALC892 8-Channel High Definition Audio CODEC sound drivers installed?
Depending on if its a LX, V, V-Pro, deluxe, etc there are different sound chips, the LX has the Realtek® ALC887 8-Channel High Definition Audio CODEC *4.
On the menu there are settings that can change the jacks:
