Trouble with C++ structs
buzzard34
What do I have to fix here? I'm trying to compile this propgram using structs and having little success. The compiler lists errors tracing back to the "word charm" function, where it says "conversion from 'wordType'to non-scalar type 'wordtype' requested" I don't really know what that means, I have a terrible time trying to figure out what the hell the compiler tells me. If anyone could help me out that'd be great.
Code:
   #include <iostream>
   #include <cctype>
  #include <iomanip>
  using namespace std;
  const int MAX_WORD_LENGTH = 20;
  struct wordType
             char word[MAX_WORD_LENGTH];
             int len;
  //Function Prototypes
  void Description();
  //Description of program
  void InitWord(wordType w);
  //Cells 0..len -1 are initialized to space character
  void GetWord (wordType w);
  //User is prompted to enter a word with less than MAX_WORD_LENGTH
  //letters. The user is then prompted to enter the word.
  void ShowWord (wordType w);
  //Precondition: w is an array which contains a word of
  //len letters stored in cells 0..len-1.
  //Postcondition: the word is displayed on the screen.
  // w and len are unchanged.
  void ShowReversedWord (wordType w);
  //Postcondition: the word is displayed backwards on the screen.
  //w and len are unchanged
  bool WordsAreSame (wordType w1, wordType w2);
  //Precondition: w1 is an array which contains a word of
  //len1 letters stored in cells 0..len1-1.
  // w2 is an array which contains a word of
  //len2 letters stored in cells 0..len2-1.
  //Postcondition: Returns true if the words are the same, false otherwise
  //Case is ignored in that Hello and hello will be regarded as equal.
  // w1, w2, len1, and len2 are unchanged.
  //Uses <cctype>
  bool IsPalindrome (wordType w);
  //Postcondition: Returns true if the word is a palindrome, false otherwise
  //Case is ignored in that AbcBa will be regarded as a palindrome.
  // w, len are unchanged.
  //Uses <cctype>
  int NumberVowels (wordType w);
  //Postcondition: Returns the number of letters that are in the set
  //{A,a,E,e,I,i,O,o,U,u}
  //w and len are unchanged.
  void DisplayWordCharm (wordType w);
  //Postcondition: The word is displayed on the screen as an ancient
  //word charm as described on the assignment.
  //Uses <iomanip> and <cctype>
  //The main program
  int main()
      wordType word1[MAX_WORD_LENGTH];
      int word1Length;
      wordType word2[MAX_WORD_LENGTH];
      int word2Length = MAX_WORD_LENGTH;
      Description();
      cout << "First word:\n";
      InitWord(word1,MAX_WORD_LENGTH);
      GetWord(word1,word1Length);
      cout << "\n\nSecond word\n";
      InitWord(word2,MAX_WORD_LENGTH);
      GetWord(word2,word2Length);
   //Test GetWord and ShowWord
      cout <<"Your first word(between the bars): ";
      cout << '|';
      ShowWord(word1,word1Length);
      cout << '|'<< endl;
      cout << "Your second word:";
      cout << '|';
      ShowWord(word2,word2Length);
      cout << '|'<< endl;
   //Test ShowReversedWord
      cout << "Your first word spelled backwards is ";
      ShowReversedWord(word1,word1Length);
      cout << endl;
   //Test WordsAreSame
      if (WordsAreSame(word1,word1Length,word2,word2Length))
          cout << "Your words were the same.\n";
      else
          cout << "Your words are different.\n";
  //Test NumberVowels
      cout << "The number of vowels in your second word is ";
      cout << NumberVowels(word2,word2Length);
      cout << ".\n";
   //Test IsPalindrome
      if (IsPalindrome(word1,word1Length))
          cout << "Your first word is a palindrome.\n";
      else
          cout << "Your first word is not a palindrome.\n";
  //Test WordCharm
      cout << "Your second word displayed as a word charm:\n\n";
      DisplayWordCharm(word2,word2Length);
      return 0;
  //Function Implementations
  void Description()
      cout << "Greetings to the fun with words program.\n";
      cout << "You will be prompted to enter two words with ";
      cout << MAX_WORD_LENGTH << " \nletters or less. The program";
      cout << " will then test your \nfunction implementations.\n";
      for (int i = 0; i < w.len; i++)
          w.word[i] = ' ';
      cout << "How many letters are in your word? ";
      cin >> w.len;
      cout << "Enter your word:";
          cin >> w.word[i];
      for(int i = 0; i < w.len; i++)
          cout << w.word[i];
      for (int i = w.len - 1; i >=0; i--)
          cout << w.word[i];
  //Uses <cctype>
      if (w1.len != w2.len)
          return false;
      else
          for (int i = 0; i < w1.len; i++)
  	    if (toupper(w1.word[i]) != toupper(w2.word[i]))
  	        return false;
  	return true;
  return true;
  //Uses <cctype>
      for (int i = 0; i < w.len/2; i++)
          if (toupper(w.word[i]) != toupper(w.word[w.len-1-i]))
  	    return false;
  	return true;
      int count = 0;
      char ch;
      for (int i = 0; i < w.len ; i++)
          ch = w.word[i];
  	if (ch == 'A' || ch == 'a' || ch == 'E' || ch == 'e' || ch == 'I' || ch
  	== 'i' || ch == 'O' ||ch == 'o' || ch == 'U' || ch == 'u' )
  	    count++;
      return count;
      for ( int row = 0; row < w.len; row++)
          //First indent the needed amount
  	cout << setw((80 - 2*w.len)/2)<< ' ';
  	cout << setw(w.len-row) << ' ';
          //Now print the row of letters
          for (int col = 0; col <= row; col++)
  	    cout << setw(2) << char(toupper(w.len[row]));
  	cout << endl;
  [/indent][font=verdana, arial, helvetica][size=2]
[/size][/font]​
You're trying to pass an array of wordType structs to functions that take a single wordType by value.
Code:
creates an array of MAX_WORD_LENGTH structs, not a single wordType like your function signatures specify.
Code:
ok so to change it, would i just make it "word"? then would it compile correctly?
It may fix one problem, but your code will still not compile.
This isn't to be rude, but there are some pretty basic problems with the program. I'd find someone to help you in person. I think you'll get your code working faster and you'll learn more.
i understand
Just one thing to add, you declared wordType as:
struct wordType
Declaring it this way, whenever you declare variables with a structure you need to preface the declared with the word "struct". Like:
struct wordType varname;
A better way would be to declare wordType as a new type, that is:
typedef struct wordType
Now when you declare variables of wordType, you can declare them as:
wordType varname;
struct wordType
wordType varname;
havent covered that in class yet.
struct wordType
wordType varname;
Not in C++, thats C. In C++ Structs are the same thing as Classes, except defaulting to Public.
To demonstrate
Code:
#include <iostream>
struct MyType
   int MyInt;
int main ()
   MyType MyVariable;
   MyVariable.MyInt = 12;
   cout << "MyVariable.MyInt equals " << MyVariable.MyInt << endl;
output
Code:
./structest
MyVariable.MyInt equals 12
