Headcase_Fargone
- Mar 25, 2010
So I jumped on the Amazon deal a few days ago to add a second card (I bit on the HIS one from a couple of weeks ago) and my card just came in. Trouble is I can't seem to unlock this one like I did the HIS, although the hardware appears to be identical.
First step I took was creating a bios file to mod with GPU-Z. I then used the MOD_BIOS_HD_6950 batch file to edit it for the unlocked shaders. I then placed the modded.bin file into the winflash folder.
Just like with the HIS I got a "Cannot erase ROM" error when attempting to load the file through the GUI. So I went the command line route which worked like a charm on the HIS card:
atiwinflash -unlockrom 0
Got my little progress bar that blinked up for a moment then disappeared.
atiwinflash -f -p 0 modded.bin
Got a second little progress bar that blinked up for a moment then... disappeared. Waited and waited but I never got a confirmation that the flash was successful.
The switch is in the 1 position that the card came in, just like the HIS. What am I doing wrong here?
