I finally decided to stop being lazy and try to get my 2600k OC'd in offset mode instead of just running it at 4.5ghz 24/7. The problem is, I can't seem to get the CPU to actually go up to the speed that I set the turbo multipliers. Currently, it will downclock itself to 1.6ghz when not under load, but when I load the cores with Prime95, the CPU never goes higher than 3.4ghz even though the turbo multipliers are all set to 45.
Any idea what the problem could be? Glancing through my BIOS, it looks like everything required to have turbo boost work is enabled. PC is in my sig if that helps. Thanks in advance.
