byusinger84
- Feb 1, 2008
I have had a heck of a time trying to get this to work. Here is my scenario:
- Vizio M70-C3 TV (one HDMI port supports 4K @ 60hz while the rest support 4K @ 30hz.
- HDMI Cable is rated HDMI 2.0 for HDCP 2.2 and 4K @ 60hz compatibility.
- HTPC System:
Fatal1ty Z170 Gaming-ITX/ac (the ONLY motherboard with onboard HDMI in a MicroATX/ITX form factor that supports 4K @ 60 hz via the optional chipset to allow 4k @ 60 hz with onboard graphics)
Core i3 6300 with Intel 530 graphics
16 GB DDR4 Corsair 2600 MHz
Samsung 850 EVO SSD
Ceton Labs InfiniTV PCIE 6 Cable Card Tuner
Windows 7 x64
Behavior:
- Using either the Intel utility or the built in Windows screen resolution panel, when switch to 4K resolutions, 30 Hz works perfectly fine. 60 Hz will black the screen out and will not display.
Things I have tried already:
- I have a Roku 4 and it can connect to the display just fine at 4K 60 hz so I'm pretty sure it's not a display issue
- Verified that I have plugged into the proper HDMI out on the motherboard (there are 2 and only 1 is for 4k60 hz)
- Purchased brand new verified and 4k60hz capable HDMI cables
- Googled it
Anyone else have ideas?
- HTPC System:
Samsung 850 EVO SSD
Windows 7 x64
Behavior:
- Googled it
