Trouble flashing ibm m1015 to IT mode
Im trying to flash my new 1015 to IT mode.
I made a dos usb stick with the data on it.
I followed the tutorials as far as the commands go but I have a problem when is type the first command:
dos log:
Code:
C:\>cd c:\sas2008
C:\SAS2008>megarec -writesbr 0 sbrempty.bin
DOS/31A -- Protected Mode Run-time  Version 7.35
Copyright (c) Suupernar Systems, Ltd. 1996-2005
Screen Picture:
then it hangs and I cant fill in any more commands
I've tried different usb sticks and I tried it in 2 systems but no luck so far.
I've also been googeling for hours no but I couldn't find I fix so I thought id just ask here.
I used this dos usb method: http://www.sevenforums.com/tutorials/46707-ms-dos-bootable-flash-drive-create.html
and the firmware is located in the SAS2008 folder on the drive.
(im guessing its a dos settings thing but I don't know shit about dos :) )
my card came with a small chip on the HS1 2pin header pn:l3-25150-00b (licence card or something)
ill now test without the card, ill post back in a few minutes.
:edit:
no luck same error as in the post above.
solved.
sadly i really don't know what cause the problem or what fixed it.
i can however say what i changed so maybe if someone has the same problem they can try it:
i remade the usb,
i put the files in the root dir on the usb,
i put the adaptert in the first pci slot,
i used a diff usb sick.
so one of those changes (or a combo) solved my problem
memphis_1220
The screenshot above has a comma instead of a dot in sbrempty.bin
That was probably it.
