I'm performing a clean install of XP but my computer isn't letting me access the BIOS to change the boot order.
I've got an ASUS AZN8X-E Deluxe and I get a load screen but access the dos screen via tab.
On my older PC's I could just hit F10, etc, and it would load my setup and bios. Now I'm just getting an error. Here's what's on the screen.
ASUS AZN8X-E Deluxe ACPI BIOS Rev 1008
It then lists my hard drives and DVD ROM and CD ROM.
Then....
Secondary IDE Channel no 80 conductor cable connected.
Then in red color....
Insert Disk press Enter or ESC to continue Post.
I hit enter but nothing. Hit ESC and it just loads to Windows.
Why does it do this? How can I change the boot sequence? If it's a problem, can I change the boot sequence another way?
Thanks
Then....
Thanks
