Triple monitor desk recomendations
Discussion in 'Displays' started by RamonGTP, May 15, 2018.
  1. RamonGTP
    RamonGTP [H]ardness Supreme
    7,424
    Nov 9, 2005
    I'm about ready to pull the trigger on a new desk. My current one is only large enough for dual monitors. Currently running a 24" and 27" and I'm toying with the idea of upgrading my primary 27" screen with a 35" ultra wide to use as my primary (center) screen with probably 24" screens on it's flanks.
  2. MrFuzzy
    MrFuzzy [H]Lite
    101
    Aug 18, 2005
    I have three one 21" is at the very edge and I got one of those pole mounts for the other 24" one and the middle is 27" fills the desk but it works you could get one of those pole mount dual monitor setups and attach that way would free up space on the desk
  3. criccio
    criccio Fully Equipped
    11,660
    Mar 26, 2008
    Ikea Galant corner desk. Discontinued but they can be found used.
    Best desk ever made for one reason.. its DEEP.
    With all the expansions available for it, you can fit as many monitors in any configuration that you could possible want.
    rtangwai likes this.
  4. HiryuuX
    HiryuuX Limp Gawd
    206
    Jul 16, 2017
    I agree with this, the Ikea Galant is a solid option (just bought a used one myself). I'd also say the new Ikea Bekant works - I would highly recommend a monitor stand as well to save space.
  5. RamonGTP
    7,424
    Nov 9, 2005
    I will have a look at the Bekant, don’t really want to buy used. Keep the suggestions coming. I’ve been thinking about the monitor stand as well.
  6. HiryuuX
    HiryuuX Limp Gawd
    206
    Jul 16, 2017
  7. criccio
    11,660
    Mar 26, 2008
    Shame about the Bekant, its nearly half the depth of the Galant. Desks like that are SO cramped, especially if you like a large mouse/desk mat.
  8. NoOther
    NoOther [H]ardness Supreme
    5,927
    May 14, 2008
