Triple boot XP (32bit), 7 (64bit), Ubuntu (64bit) on a 3TB drive
Discussion in 'Operating Systems' started by Bontakun, Jul 17, 2014.
  1. Bontakun
    Bontakun [H]Lite
    97
    Aug 15, 2010
    How do I seamlessly make a triple boot of XP (32bit), 7 (64bit), Ubuntu (64bit) on a single 3TB hard drive without needing to switch between UEFI and BIOS? I'm trying to make 7 the largest partition, and the other two smaller. I know MBR has a 2TB limit, but is that limit per drive or per partition?
    Thanks in advance.
  2. xLokiX
    xLokiX Limp Gawd
    263
    Jun 10, 2007
    Partition the drive into the 3 sizes you want. Install XP first, then 7, and Ubuntu last so grub doesn't get messed up. It would be easier and quicker to just install windows 7 and then make Vm's of XP and Ubuntu though. Is there any reason those can't be virtualized?
  3. Armenius
    Armenius I Drive Myself to the [H]ospital
    16,202
    Jan 28, 2014
    The partition table is for the whole disk, so using an MBR would limit the drive's capacity to 2.2TB. It would be a shame to limit that disk to 2.2TB. If I were you I would set it up with a GPT and virtualize XP inside of W7 so I could access the max capacity of the drive.
  4. Tsumi
    Tsumi [H]ardForum Junkie
    12,928
    Mar 18, 2010
    Virtualization would be the best unless there was some technical reason you can't do it.
  5. DeaconFrost
    DeaconFrost [H]ardForum Junkie
    10,949
    Sep 6, 2007
    That's what I was thinking. You can do it at no cost, and still utilize the other OSes. It simplifies your setup, and allows you to use more than one OS at the same time.
  6. rhansen5_99
    rhansen5_99 [H]ard|Gawd
    1,964
    Nov 12, 2001
  7. Unknown-One
    Unknown-One [H]ardForum Junkie
    8,867
    Mar 5, 2005
    It's actually only about 500GB of extra space (a 3TB drive is really only 2.72 TB)
